Where was it?
exatly where you pointed out. where the fuel rail connects to the HPFP. but only when it was a cold start and cold outside. so when it was -15 out it really leaked!
Where was it?
Decided to pick up a used modshack intake and give it a try. Much better than the neuspeed pflo. Power is smooth and even all the way through. No loss of low end or lag at the start. Also, very quiet. Love it so far.
Sent from my SAMSUNG-SM-N920A using Tapatalk
What's the difference between the two APR classified theirs between stage 1 and stage 2 not sure what exactly the stage two connects to but do both go to the same place or does 1 use stock maf sensor location?I'm not saying it is an enormous gain, but it definitely gave the car quicker throttle response and slightly better power through out. I only have the neuspeed to compare to amd that made the car sluggish at the low end and you won't feel it until you are above 4k rpm. The modshack is more usable as a daily.
well crud now i want to trade my neuspeed lolI'm not saying it is an enormous gain, but it definitely gave the car quicker throttle response and slightly better power through out. I only have the neuspeed to compare to amd that made the car sluggish at the low end and you won't feel it until you are above 4k rpm. The modshack is more usable as a daily.
Neuspeed is a good product. It just doesn't work for me because I spend most of my time between idle and 3500 rpm. The neuspeed made driving in traffic and city unbearable for me. I really like the quick an peppy take offs and the neuspeed got rid of that. The modshack feels more like stock buy better and smoother.
Might buy a BSH true seal intake. friend is buying my Pflo
If I found/won $1k I would run straight to the nearest umitronic tuner and get the ecu+tcu combo deal.I'm stage 2 with the I.e. Intake and drive pretty much in the same conditions as sniper and I don't feel it that sluggish at all especially being stage 2 tune. It's a really great intake and love the sounds it makes when boosting and letting the dv do its thing. I also have dsg tune tho not sure if that affects the comparison to the driving since it has faster shifting than normal tune
