staynhome29
So I was led to believe that a stiffer front spring allows a fwd car to get a little more loose around turns whereas a stiffer rear spring (relative to the front) will create understeer.
Now some recent articles are saying a stiffer rear spring will create more oversteer.
Track testing has shown me that tire psi also play a role in causing oversteer and understeer to some degree. I run 36F (hot) and 39R (hot) psi and car rotates much better this way.
My goals are:
1. Stability and grip on medium-high speed sweepers
2. Great turn-in, lift-off oversteer for the tighter transitions.
I also noticed that most "track" dedicated coilovers come with higher rates for the rear then the front.
But KW Clubsports and AST4100s come with heavier front springs than rears.
I was wondering why the differences?
My goals are:
