hey mike, I just had one of the forum members help me code the emergency break lighting where if I were to break hard enough, it'll flash the breaks & side indicators..
I tried it out in a parking lot, didn't quite reach 50-60km/h, ABS activated but the lights didn't trigger.. do you know if I have to exceed a certain speed limit for this to occur?
thanks!
Any settled pics of the springs Mike?
I think I might do a light drop + wheels in the spring.
Thanks much to zVp and everyone else for the well organized and very helpful vagcom screenshots!
^i don't think so man. In pretty sure everyone would do that instead of the regular key fob vagcom tweak if it was available
LED Tail-lights Coding & Error Clearing
Thanks to ZIPN VW at http://forums.vwvortex.com/showthread.php?4898893-LED-tail-Install-with-or-without-Rear-Fog.
How-To
WARNING: I will not be held liable if anything occurs when attempting to change anything in the VCDS software. These instructions are created to the best of my knowledge and are as accurate as I can make them. Please be careful before you save your settings and always run Auto-Scan before any changes are attempted.
Load up VCDS, click on the Select button under Select Control Module
Click on the 09-Cent. Elect. button
Click on the Coding - 07 button
Click on the Long Code Helper button
You will have to find out where byte 18 is as indicated by the arrows in the above image on the 1) line (with the yellow texts). Place your cursor on that area and change the two (2) digits to the respective and known codes listed below (please be careful!):
Xenons Headlights without Rear Fog
1F, 20, 55
Cars with LED DRLs - 21
Xenons Headlights with Rear Fog
15
Cars with LED DRLs - 04 (Golf R, 2012 GTIs, etc)
Halogen Headlights without Rear Fogs
1F
Halogen Headlights with Rear Fogs
22, 15
WARNING: SAVE your auto-scan before doing this. If you change any digits incorrectly, a whole bunch of errors/issues/etc. will occur. I will not be liable for you incorrectly coding your tail lights.
NOTE: Side-effects of coding may include hatch tails staying lit when open, side markers at low brightness, city lights as high brightness, etc. If this occurs, try another code. If none of the codes work for you in the list, please research or ask for help in the forums.
Press exit on the top left of the window.
This window will show up again. Press the Do It! button to save your work.
WARNING: Please review all your coding before saving your work.
Back to this window, press the Faults Code- 02 to start the process of clearing the bulb-out error on your dash.
This window will pop up and show you numerous errors regarding your tail-lights. Press the Clear Codes - 05 button.
Press the Yes button to clear the codes.
Once this is complete, the bulb-out error on your dash should disappear and no faults should be visible in the faults window. If there are any faults left, try another code and repeat these steps.
Hi Man
I have a problem with the Telephone, everything is working perfect except that I hear the voice of callers low -but it is clear- even when I increase the volume to the maximum I still hear them a bit low.
Do you have any code or settings that can help.
Thx
Here are the details:
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 L HW: 1T0 035 680 C
Component: RNS-MID H41 5269
Revision: AB001001 Serial number: VWZ6Z7K5238074
Coding: 04050402040000900000
Shop #: WSC 01357 011 00200
VCID: 373EEB9A86A907FA4D-8062
Subsystem 1 - Part No: 7L6 919 859 G
Component: AUNZ V7 8035
No fault code found.
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 J HW: 7P6 035 730 J
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007662981511
Coding: 0210000000010110
Shop #: WSC 00015 115 12345
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_002.rod
VCID: 393AEDA2B8BD118ABB-806C
Sorry man, I'm not sure of any settings that can make the volume higher.
Is it just your phone? Does your media player on your phone work at higher volumes?
All Lights Shut Off When Turning Off Vehicle
Thanks to Tim S for these instructions
How-To
Click on Byte 15 and check mark Bit 5 - Parking Lights OFF with Terminal S OFF and Light Switch at Low Beam
All lights should be off when the key is out of the ignition, even if you have your light switch to the far right (everything on). The default setting would leave parking lights (front and back) on after taking key out of the ignition.
I guess this would save your battery in case you forgot to turn the light switch to off, but I am not 100% sure about this.
