Boobslappy
Finally finished my 42dd install on the R (cat, no res) and I wanted to add my thoughts:
First off thanks for THIS THREAD.
-The top inner flange bolt was actually the easiest for me because I had room to get a very large ratchet in there to break the bolt loose. You just need a couple long extensions and feel for the nut.
-Turbo flange bolts are 17mm on the R
-Buy a ratcheting gear/box wrench BUY IT!!!!
-Do your top work before you jack and try to get the top O2 sensor and top 2 flange bolts out straight away
-I was able to remove the front portion of the drive shaft and center support and then move the drive shaft to the passenger side of the tunnel to pull out the stock down pipe. This is a requirement on the R and you need a 10MM 12 POINT Socket for the 3 drive shaft bolts
-put in the down pipe and secure it loosely to the turbo THEN tighten your drive shaft back up (you can align the holes by turning the driver side wheel by hand)
Most of this info is scattered around various threads but just wanted to reinforce some info for the newbies like me doing this and save you some hours.
