Black Forest Industries Catch Can V2 information thread
black forest ind
Seriously look at it. Would you just look at it!? Our Clean Catch Oil Separator functions as good as it looks and without removing the factory PCV. This gives you multiple lines of defense against carbon build up while elevating the look of your engine bay rather than detracting from it.
Our brand new Version 2 design features a perforated cylindrical baffle to maximize the amount of surface area while still allowing air to circulate freely. This allows all harmful oil vapor to collect on our cylindrical baffle, and ultimately drain into the can and not the back of your intake valves.
Our new upgraded heat resistant braided hoses give an additional layer of protection and durability as well as make for an extremely OE+ look. Their woven look, complete with white detail is as factory as it gets.
In addition to all of our new functional upgrades we have also added the ability to customize the look of your car by adding additional anodized hardware. You can now select from a large range of colors that compliment your build and give that perfect appearance.
We were the very first company to offer actual OEM hose connection, direct from the supplier who makes them for VAG. We employee a proprietary method to mount them to our hosing to ensure and exacting fit every time, with no third party or unnecessary aftermarket solutions. In this instance there was no need to reinvent the wheel, so we designed our kit around what already existed.
We have also changed the way our can mounts to our proprietary bracket, now with a bolt in fit, rather than using the can lid to mount. We feel this still efficiently and succinctly solves the task and also gives an attractive six shooter / revolver impression.
MLue1
"We were the very first company to offer actual OEM hose connection, direct from the supplier who makes them for VAG."
Very nice products you got there, sorry I don't need a catch can for my Golf 2.5 BUT my stock PCV Breather Hose between the Air/Oil Separator and the Intake Manifold is in need of replacement. If you are able to build one for me using the stock VW Norma connectors and the braided/re-enforce hose I would be prepared to buy it for a bit more than the stock VW part (07K103211B).
Since you may have a few of these connectors in stock, maybe you would consider adding the PCV Breather Hose (07K103211B) as a future product, .... it does adds a bit o "bling".
black forest ind
Unfortunately, we have to buy the hose to get the connectors, and I spoke with our development team and they stated that it would be rather hard to make a bigger hose to go into that tight space. I guess there are certain bends that the OEM hose can do with ease compared to something that would be thicker. Plus, it may not be any better than the OEM one.
MLue1
There is a thread on this forum that indicate that if we cut our old connectors off, that the 5/8 inch plastic works perfectly with the AN fittings for the braided hose, unfortunately my connectors are now 10 years old so looking for replacement.
Hopefully, someone sooner or later will start making them up the profit margin is there, compare what a single OEM hose sells for (Link), versus one hose in your Catch Can Kit for the 2.5
Wascally Wabbit1
Which fittings are you looking for? PCV? I have a set I can send you if you PM me your address.
MLue1
Thanks Chris, I want to put the stock intake manifold back on for the winter, I need a new PCV Breather hose (5/8 ID), not just the fittings. Are you able to make a 5/8 ID Hose for me?
Wascally Wabbit1
Thanks I'll accept your offer, make it stock length preferable. I'll PM you my address. I know you spent $$ experimenting with the PCV so I'll be happy to pay it back. :thumbsup:
My pleasure. I got the fittings sorted today and just need to get the right length.
Wascally Wabbit1
Can't make it stock length as it bends the tubing too much and puts stress on the connectors. Came out a couple inches shorter but that shouldn't matter at all. I.D. is spot on.
https://imgur.com/a/sNtDllC
https://imgur.com/a/kAUvKDj
