As mentioned previously in this thread, there was/is a TSB for the earlier cars for the wiring. My car already has the updated wiring according to my dealer.
I have no code, stored or otherwise. I wish I did, this would be much easier.
To update: I replaced the throttle pedal & the issue persists. I performed a TBA after replacing the pedal.
It seems I'm (likely) chasing an air leak of some sort even though the car was check for vacuum leaks. Alex at Stratified has suggested the same.
I'll update with results. At this point I'm actually hoping I have a boost leak.
I'm planning a boost leak test as soon as possible.
