brobst
Upgrading subframe mounts & subframe bolt information
Anyone with experience installing the VWR subframe pucks, does the subframe has to be removed from the vehicle? The directions say to press the puck in, but seeing as it is metal on the outside, I do not see how it could deform.
Which leads me to believe it should slide right in.
Some thread searching has some folks installing it, but their subframe was already off the vehicle.
http://www.golfmk6.com/forums/showthread.php?t=37933
http://www.golfmk6.com/forums/showthread.php?t=50705
I am wondering, if we just lower it so we can remove the old top mount if the new one will slide right in? Like when you do a front sway bar install, the subframe is lowered but not entirely removed from the vehicle.
We are doing this on jackstands, so leverage is limited.
This may be the closest to what I am looking for. Anyone can confirm more recently? I swear every time I read you don't need a press, another thread makes it seem like you do.
http://www.golfmk6.com/forums/showthread.php?t=86987
http://www.golfmk6.com/forums/showthread.php?t=75312
Thanks.
EDIT: More searching, has me turning this into a compilation thread. For all future persons interested in this mod, the information will be here.
Update: Here is the subframe diagram below. In order to remove the subframe and place the mount, it appears that this list of bolts needs to be removed and replaced. Ignore the numbers written on the sheet. The correct list is here.
If replacing dogbone
29 - N91167101 (1x)- M10x35 [Dogbone specific] (034 motorsports states 45Nm with blue loctite)
28 - N91066101 (1x)- M10x75 [Dogbone specific] (034 motorsports states 45Nm with blue loctite)
30 - N10558002 (1x)- M14x1.5x70 [This one goes through the 2 subframes and the pendulum] torque 50nm (note 034 motorsports calls for 100nm w/ blue loctite. Note sure, probably depends on aftermarket or not)
If doing the Tyrolsport deadset kit
33,34 - N91039802 (4x)- M12x1.5x90 torque 70nm
35 - ARP bolts supplied (2x) torque 85nm
Note: Some sources replace 34 with the OEM passat bolts N90823501 M12x1.5x110 torque 70nm
Directly unbolting the subframe
subframe to body bolts with 18mm socket 70nm
subframe/suspension bolts with 16mm socket 50nm
sway bar bracket bolts 13mm socket 30nm
5 - N10528602 (2x) M12x1.5x75
6 - N91073401 (4x) M8x75 torque 30nm
(6) - N10579702 (3x) M10x76
Note 35 is done here as well. I have it listed under the dead set section though (2x)
Extra information listed. Not necessary but useful for later
31 - N10579702 (4x) M10x76 torque 50nm
2x N10141003 - Front LCA Bolt18mm
6x N10332002 nut for LCA
-LCA change out
Part #s
4x N10579702 - Rear LCA Bracket Bolt Inside 16mm
2x N91039802 - Rear LCA Bracket Bolt Outside 18mm
Installation
1. Removed the 3 ball joint nuts (16mm)
2. Removed the front LCA bolt (18mm)
3. Removed the rear LCA bracket (1x 18mm, 2x 16mm)
4. Lube bushings with supplied lithium grease, or your own choice of lithium grease
5. Slide in rear LCA bracket onto the control arm
Thread in the bolts loosely before torquing to specification, so you'll have a little more wiggle room trying to line things up.
6. Install/mount up the rear LCA bracket (1x 18mm, 2x 16mm)
a. 18mm - 52ft/lb + 1/4 turn
b. 16mm - 37ft/lb + 1/4 turn
7. Install/mount up front LCA bolt (18mm)
a. 18mm - 52ft/lb + 1/2 turn
8. Install/mount up the 3 ball joint nuts. (3x 16mm)
a. 16mm - 74ft/lb
9. Check/Tighten all bolts with torque specs
If you need more information, refer to this thread: http://www.golfmk6.com/forums/showthread.php?t=95863
Thanks everyone for the help putting this together and the pictures.
Thanks.
-LCA change out
Part #s
Installation
a. 16mm - 74ft/lb
