mg_90
mg_90 can you tell me how did you do the canister delete? And maybe you have some photos of your underhood? i want to delete it too!) Hope you`ll help me!)
Removing only the canister, which is what I did, and leave the rest of the system to avoid any CEL is really easy. I did it about 2 years and 30k miles ago and haven´t had a single problem.
You only need to buy two K&N RU-3230 filters, or from other company with the same specifications, the K&N work perfect because they have the required inside diameter, remove the canister and place the filters in place.
Remove the line that goes from here to the canister and put one filter, or run a line to under the car.
And cut the line from the canister to the N80 and place a filter here.
Here is what the engine bay looks like.
Hope this helps! :thumbsup:
