I have a set of Tiguan wheels, and they are 18x8 et 30.
Fronts fit perfectly, with a 215/35.
Rears I'm having issues. I'm getting some rubbing and I'm pretty sure if i get an alignment I can add some more negative camber and the tires will fit in the back. Tire size is 215/40.
I'm 23.5ftg all around, and I'm wondering if anyone has a similar set up/what alignment specs are you running. I know people make these specs work, as I've seen people run far more aggressive setups on coilovers.
Specifics:
Coilovers: H&R ultra low
Wheel spec: 18x8 et 30
Tires: 215/35 up front 215/40 in the back. Yokohama S drive
23.5 FTG on all four corners
Thanks!
P.S. I havent gotten an alignment since i lowered the car, but right before it was lowered the car did have an alignment, and everything was in OEM spec.
Specifics:
Thanks!
