SoCalMK6GTI
So I've been paying close attention to this and temperature (outside) doesn't seem to be a variable.
1st - 3rd gear at a steady throttle and watching my boost gauge I notice the needle rising up until about -2 to 0psi/Hg and then the RPM's still continue to climb while the boost gauge doesn't move, then there is a moment when both RPM's and boost climb at the same time. This happens in 1st - 3rd gear only.
I have a couple of theories on this.
1) it's the new revised flash that fixes this
2) there is a thread on how the Carbonio intake might be causing a vacuum within its own housing which chokes up the intake momentarily. (this only makes sense because at lower speeds the intake is sucking in air where at higher speeds the outside air is being rammed into the intake)
Just a couple of theories.
Any other thoughts are appreciated. I'm getting a reflash this Saturday so I'll know then if that changes/fixes anything.
