Beaker1
Yeah you definitely need to run stock file to get all the O2 sensors to read. It typically takes about 30 miles plus to have enough data for the emmisons folks to read from the obd. I was cbfa and I ended up having to run 2 02 spacers. Some folks on cbfa only had to run 1 02 spacer. Really just depends. So yes clear your code run it in stock file and see if you code again..if you do try a 42dd spacer and start over again.Help!
I'm trying to get my car to pass emissions. I have Apr k04 v3.1 and a downpipe with a 400cell cat. I had the etest done on my 91 octane file and of course oxygen sensor isn't ready.
I put it back to stock mode and got a cel. Do I need to use vcds to clear the cel, force readiness and then go to emisiion test before the cel comes back on? Or do I need a 02 spacer or is it something completely different?
Sent from my SM-N920V using Tapatalk
