I replaced the entire sensor, cleared the related codes, took it for a test drive but I'm still getting the AFS Failure message on the dash and the following codes below. I re-checked the wiring connector to the sensor and it's on tight. Going to check the AFS controller next. Any thoughts on this would be much appreciated!
Friday,13,March,2015,14:58:06:03440
VCDS Version: Release 14.10.2 (x64)
www.Ross-Tech.com
Address 55: Headlight Range Labels: 5M0-907-357-V2.lbl
Control Module Part Number: 5M0 907 357 C HW: 5M0 907 357 C
Component and/or Version: AFS-Steuergeraet 0142
Software Coding: 1446940
Work Shop Code: WSC 01357 011 00200
Additional Info: 7L6941329B AFS-Lst.-Modul l 0004 7L6941329B AFS-Lst.-Modul r 0004
VCID: 346C892D57361F81BA7-8061
2 Faults Found:
00497 - Sensor for Vehicle Leveling; Rear
010 - Open or Short to Plus - MIL ON
Freeze Frame:
Fault Status: 11101010
Fault Priority: 3
Fault Frequency: 3
Reset counter: 35
Mileage: 103430 km
Time Indication: 0
Date: 2062.14.10
Time: 14:35:03
Freeze Frame:
Voltage: 13.77 V
Speed: 0.0 km/h
ABS 1
01539 - Headlights Not Adjusted
005 - No or Incorrect Basic Setting / Adaptation - MIL ON
Freeze Frame:
Fault Status: 11100101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 35
Time Indication: 0
Freeze Frame:
Invalid
Invalid
Invalid
