It was very easy. It asks for vehicle weight. I don't know what mine is. I guessed 3100. Then you select a gear. I went 3rd. Then you select an rpm range. I went 2000-6000. The AP waits for you to get in gear and rpm range and displays the data when done. I will have to check when I get home and see if it logged the data. I don't know the optimal dyno conditions, but if you want me to try different gear and rpm I will
To the guys having issues, make sure you put in the correct weight and gear. The COBB should have the MK6 Aerodynamical profile in there, and the only other thing to account for is temperature which I think you can actually change. Just not sure how.
My clutch with 40k miles on it was not happy in 3rd gear on up so I reverted to the Stage 1 91 map and there's only the slightest bit of slip in 3rd for now. I'll be looking to upgrade to the Sachs SRE in the near future depending on how long I feel like babying the stock clutch.
So far, so good. Only about 30 minutes with it, mostly on the highway. I'll be playing with it a little more this weekend.
what? could you elaborate for those of us who dont have the AP?Best part is the custom splash image on AP.
I wanted to put mine on the right, but there wasn't a good spot to place it that didn't block the radio. I choose the left side beside the light switch. The mount comes with 3m tape and mine didn't stick very well and already came off. I gotta figure out a new mounting option. [emoji22]Looks pretty. Did you try putting it on the right. If i get it i dont want the AP to block a vent.. but i want the gauge mode to run just for the funs
You can actually change the startup image to what ever you want. Mines a glamour shot of my car.It's just a picture of a GTI.
