ryandm1984
Ok, first, this I did out of pure curiosity while in my shop one day. I used to have the light wrapped in 3M carbon fiber vinyl but it was a little faded. So, I peeled the vinyl off thinking I could live with the factory orange. Couldn't do it. So this is what I came up with...
This is the roll of aluminum tape, you can get this at any hardware store and I think even Walmart, it's about 5 bucks or so.
Remove your side marker light by removing your your access cover from the fender well. It has a small lip for you to pull outward to remove, it's right behind your fog light.
Once you have the cover removed, feel on the backside of the side-marker light for a tab which is the side closest to the wheel. When you feel it, push it toward the front while pushing outward from the bumper. Once it's out, disconnect the bulb.
Clean the side-marker light very well, using rubbing alcohol or something to remove any waxes or polishes from the surface. Make sure the surface is dry before applying the aluminum tape.
When applying the tape, go slow unwrapping it from the roll. If you crease it or lose the smoothness of it, it will always be there and you will have to reapply it. I slowly and carefully laid it over the the light, and once it was applied, I lightly smoothed it to the surface of the light. After it's on the light then you can firmly press all around to ensure it bonds to it.
As you can see in the pic above I pulled it around the corners and trimmed the excess off. You have to work with it to get it to lay clean around the corners, since it isn't vinyl it doesn't stretch. I used a heat gun to soften it up a bit to get it as smooth around the edges as possible.
Once you have it applied, just simply re-install to the bumper and your done!
I personally thought it looked different but looks pretty good for a quick 5 dollar job. So if you aren't in a budget for some paint matched markers, this is perfect to get you by. Enjoy!
****Note: This has NO opacity, it will completely block the light.****
