dcpppf
Once this is done, are the headrests still adjustable to the stopping points? Or do they just slide all the way up and all the way down without stopping?
I have yet to do this, but I would assume that everything will still work as normal except for the fact that you can now pull them all the way out. The left side of each headrest seems to have the permanent pin to stop the headrest from being fully removed, and the right side has the release spring loaded push button that will lock in to the different height positions. Since the right side is not being modified it should still work the same way, but that permanent pin on the left side is now gone allowing the headrest to be taken out.
Correct me if I am mistaken.
