FL_GTI
I don't think the boost control would compliment the f23t well because 3.1 uses a lot of surge protection before 4k. With the f23t you can make gobs of torque low down because it's much more surge resistant than a k04. Running it on 3.1 would kind of defeat the purpose of the turbo unless you don't use the n75 at all. Even then I'd keep a close eye on things down low because the whole tune was built around the original k04 boost curve.
Certainly valid - correct me if I'm wrong here - wouldn't it make sense to purchase the F23T at a significant discount over a standard K04 kit and run an off-the-shelf file? Any drawbacks to this methodology?
Obviously you would loose certain characteristics which make the F23T a viable option in the first place, but you gain standard, if not marginally better K04 performance for a discounted rate?
Rotary ran it for a bit when he first got the f23 iirc, night not have been the 3.1 though.
Thanks!
Nope. APR 2.1 with a MBC.
Was it a necessity to run the MBC as a control to prevent over-boosting the N75?
