soldier0829
Is it common to push oil with the K04? After my last track day I noticed a film of motor oil had accumulated on the intercooler plumbing, crankcase, TOP, etc. I can't find an obvious leak anywhere.
I too am experiencing this same problem. There is oil residue around the coupler that goes to my AWE TOP pipe and around the DV as well as the oil return line. I dont know which one of these is causing the seeping oil leak..
I'm wondering if the gasket on the oil return line on the bottom of the turbo has a specific orientation to be effective. It's the only part of the install I was unsure about, and only thing I can think of where oil could come from in that area.
I actually bought an extra gasket for the oil return line but have not had time to install it. It was a couple bucks at the dealership.
Face it towards the cartridge. Not the line.
The silicone elbow always leaks/seeps. You need it as tight as you can, and that won't happen with a screwdriver. You need a socket, but don't rip it.
EDIT/UPDATE
Advice from Grambles regarding the gasket orientation
Follow up advice from 2013R, who's gasket also "faces the line" like mine:
I have about 200 miles of driving to do tomorrow afternoon - I'm going to get up early and do both these things and clean up all the residual, drive it hard on the trip, and then recheck on Wednesday to see if it resolves the issue
What about clogged or bad crankcase breather valve?
