speedster
Springs for the rear just came in and I finished the install.
In my opinion 8" front and 9" back is perfect. I'm at 25 1/4 " front and back. No visible gap but a good inch of clearance inside for the wheel.
I went with 280 lbs/inch spring rate front and back. Its really smooth. I think you could probably go 336 lbs/inch in the back without sacrificing ride quality too much.
60mm ID for the rear fit fine.
I'll probably set the rear sway on stiff to tighten up the rear a bit and balance the car out. Right now I slide on all 4 tires but its sliding more in the front than rear.
I'm headed to Laguna Seca next month so I'll report back on handling.
