Here's some more
Disable Electronic Stability Program (ESP)
http://www.golfmk6.com/forums/showpost.php?p=818981&postcount=294
Navigation Input Speed Threshold
http://www.golfmk6.com/forums/showpost.php?p=818974&postcount=293
Enable/Disable Indirect Tire Pressure Monitoring System (TPMS)
http://www.golfmk6.com/forums/showpost.php?p=818955&postcount=292
Torque Steer Compensation (TSC) Settings
http://www.golfmk6.com/forums/showpost.php?p=818943&postcount=291
Dynamic Steering Recommendation (DSR) Settings
http://www.golfmk6.com/forums/showpost.php?p=818815&postcount=290
Enable Tear Drop Wiping for Front Window
http://www.golfmk6.com/forums/showpost.php?p=818801&postcount=289
Adjusting Bi-Xenons Headlights Range/Level
http://www.golfmk6.com/forums/showpost.php?p=818765&postcount=288
Thanks again for making all this in one thread - it sure helps, even when I need to remember how to do all these settings in VCDS.
EDIT: Added another
Driver Steering Recommendation (DSR) Settings
http://www.golfmk6.com/forums/showthread.php?p=818996&posted=1#post818996
Now, this is a bit troubling to me. Driver Steering Recommendation (DSR) in the Steering Assist module is different than the Dynamic Steering Recommendation (DSR) in the ABS module.
Now, which one is which? In the sourced thread of
http://www.golfmk6.com/forums/showthread.php?t=25039, they talk about the DSR setting in the ABS module as the little tug from the steering wheel that attempts to make you turn the wheel a bit more. HOWEVER, I don't think this is the case.
There is another DSR setting in the STEERING ASSIST module which may be the RIGHT one for this.
I believe the DSR setting in the ABS module is actually the Dynamic Steering Recommendation (DSR) which control how the electromechincal steering acts at certain speeds.
I don't really know how to test this, but it's just a little irkling that I got when making these tutorials.
