do you know wich ones i need and how to install them??You need to add resistors, not sure it can be coded out.
Enviado desde mi SM-N920T mediante Tapatalk
I didnt update to 16.xx because it was giving some compatibility message. My suggestion would be to make a change you know works to confirm its not a version issue. Then troubleshooting the value.Trying to enable front tear drop on a 2011. I get the following error when I try to commit. Latest firmware and software build of VCDS 16.8 with HEX+CAN.
"vag com error 31 request out of range"
Thoughts?
Hi I have an issue with big speed at MFD.
My 2013 Tig is from US.
My big speedo shows MPH, if I enable Alternative (small speedo in MFD it shows in KMH). My big analogue speedo is only in MPH.
I need the big speedo in MFD to show in KMH. How can I do it? I changed region with VAG COM to ROW or even Germany its still shows in MPH plus I get fault codes (airbag, abs). When I go back to US mode the fault codes disappears.
Guys do you have any suggestions? By the way I also changed region to Canada. No fault codes but big MFD speedo is still in MPH.
I know its the Tiguan but may be for Golfs its the same issue?
I thought that was the limitation of that tool.using the obdeleven is there a way to type in the original coding to get back to where i was?
I'm sorta good at using the program but can't find a place for the long code to be typed in.
Sent from my SM-G920V using Tapatalk
