DallasDub94
Hello guys I'm still trying to get my car running right. I've narrowed the culprit down to the MAF sensor or something related. When I unplug the MAF, car runs fine, pulls hard, hits target boost and fuel trims are decent. MAF plugged in, hesitation at low rpms, can’t build boost(bleeds off via wastegate), and I get a epc/cel and then limp mode if I use more than 50% throttle.
Faults scanned via accessport are:
P0606
P0068
P050A
Also scanned using Vcds, codes seemed more accurate
P1335
P0068
P050A
P2261
Two of which are MAF related. I've already tried replacing the sensor with a new one, no change at all. The car is being tuned by stratified. The only thing I can think of at this point is that the tuner calibrated for Cobb’s MAF sensor and not the stock one. Anyone experience anything similar, or have any suggestions on how to fix. I emailed my tuner about the MAF but I'm guessing I won't hear back till after Christmas.
Almost has to be a tune issue at this point right? I've already tried, adjusting my wga, changed my diverter valve and replaced sensors, no change at all.
Thanks for any help.
Vcds scan:
Saturday,16,December,2017,01:36:56:51301
VCDS Version: Release 17.8.1 (x64) Running on Windows 10 x64
www.Ross-Tech.com
Address 01: Engine Labels: 06J-906-026-CCT.clb
Control Module Part Number: 1K0 907 115 AS HW: 1K0 907 115 AA
Component and/or Version: 2.0l R4/4V TFSI 0040
Software Coding: 0403010A1C070160
Work Shop Code: WSC 01357 011 03080
VCID: 77A8E4DED3C1C2EF6BB-8022
4 Faults Found:
004917 - Engine Torque Monitor 2
P1335 - 000 - Control Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 8
Reset counter: 255
Mileage: 98977 km
Time Indication: 0
Date: 2017.11.14
Time: 16:50:51
Freeze Frame:
RPM: 2119 /min
Load: 56.4 %
Speed: 28.0 km/h
Temperature: 56.0°C
Temperature: 28.0°C
Absolute Pres.: 990.0 mbar
Voltage: 13.843 V
000104 - MAP/MAF <-> Throttle Position Correlation
P0068 - 000 - - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100000
Fault Priority: 0
Fault Frequency: 113
Reset counter: 255
Mileage: 98953 km
Time Indication: 0
Date: 2017.11.11
Time: 22:17:12
Freeze Frame:
RPM: 3188 /min
Load: 7.8 %
Speed: 63.0 km/h
Temperature: 97.0°C
Temperature: 30.0°C
Voltage: 13.589 V
001290 - Cold Start Idle Air Control System
P050A - 000 - Malfunction - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 98964 km
Time Indication: 0
Date: 2017.11.12
Time: 15:21:47
Freeze Frame:
RPM: 869 /min
Load: 74.5 %
Speed: 0.0 km/h
Temperature: 31.0°C
Temperature: 21.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.716 V
008801 - Boost Pressure Control Valve (N249)
P2261 - 000 - Mechanical Malfunction - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 30
Reset counter: 255
Mileage: 99424 km
Time Indication: 0
Date: 2017.11.29
Time: 16:04:10
Freeze Frame:
RPM: 2721 /min
Load: 8.6 %
Speed: 36.0 km/h
Temperature: 86.0°C
Temperature: 33.0°C
Voltage: 13.843 V
Readiness: 0000 0001
P0606
P0068
P050A
P1335
P0068
P050A
P2261
Vcds scan:
www.Ross-Tech.com
4 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 8
Reset counter: 255
Mileage: 98977 km
Time Indication: 0
Date: 2017.11.14
Time: 16:50:51
Freeze Frame:
RPM: 2119 /min
Load: 56.4 %
Speed: 28.0 km/h
Temperature: 56.0°C
Temperature: 28.0°C
Voltage: 13.843 V
Freeze Frame:
Fault Priority: 0
Reset counter: 255
Mileage: 98953 km
Time Indication: 0
Date: 2017.11.11
Time: 22:17:12
Freeze Frame:
RPM: 3188 /min
Load: 7.8 %
Speed: 63.0 km/h
Temperature: 97.0°C
Temperature: 30.0°C
Voltage: 13.589 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 98964 km
Time Indication: 0
Date: 2017.11.12
Time: 15:21:47
Freeze Frame:
RPM: 869 /min
Load: 74.5 %
Speed: 0.0 km/h
Temperature: 31.0°C
Temperature: 21.0°C
Voltage: 13.716 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 30
Reset counter: 255
Mileage: 99424 km
Time Indication: 0
Date: 2017.11.29
Time: 16:04:10
Freeze Frame:
RPM: 2721 /min
Load: 8.6 %
Speed: 36.0 km/h
Temperature: 86.0°C
Temperature: 33.0°C
Voltage: 13.843 V
