New RCD330 Plus Headunit with Mirrorlink/Carplay
gokturks
Banned
Do you have any images to show what you mean by red menu?
iceorbital1
i'd love to code dynaudio support on the radio, but vcds will crap out with an out of range error when trying to change any of the relevant bits on 56 radio. I have a 2012 golf R with nav and dynaudio, so i wonder if i need to disable anything on can gateway to get the car to forget the old rns315 and accept the codings for the RCD330.
I read a lot of forums here and there, but nothing seems to work for me. Any ideas?
Been messing around with vcds settings
Looks like the way amps work, you do need to select a sound system in byte 1, or eventually things will crap out. The explanation is here http://www.vwgolf.net.au/showthread.php?2979-RNS510-Sat-Nav-Golf-R&p=79167&viewfull=1#post79167
Because the radio uses the same physical output wires (the speaker wires) for low level and high level output internally there is an electronic switch that switches the preamp to output to the speakers wires to go to the Dynaudio amp or the main Amp power amp output to the speaker wires (no Dynaudio).
So you can see if you leave it coded to Dynaudio the pre amps are driving their little transistors off to drive your huge speakers and eventually they will give up the ghost.
Apparently if an amp is fitted (dynaudio) the output stage power is 12db (which i am guessing the unit is set to now as the volume levels are greatly reduced compared to the RCD510). The output level needs to be changed to 26db via VCDS as shown in http://www.my-gti.com/1411
Now the interesting thing is of all the options available in byte 1, vcds won't accept (will through an out of range error) dynaudio or vokswagen sound systems. It does accept skoda sound system, but i still think the sound is worse than with the rns 315.
Question is, is the out of range error result of vcds lack of knowledge on the rcd330g unit, or does indeed mean that the rcd330g radio does not support any amp except skoda's ? And are the skoda and dynaudio amps any different? Will something break down the line if setup one way (skoda sound system) or the other (sound system not installed?)
GtiJase
Just thought I would put this here as reference. This is from Bashl0r from motor talk.
Have in another forum an update for the radio with HW: 534 on SW: 5314 found.
The menu should be red after the update and Android Auto available.
Another update ( SW: 5515 ) for the same model with HW: 534 is also available but which should be verbuggt. Bass - Mid-Treble are greyed out in the menu and can not be adjusted.
Apparently also an update for the 187A give on 5314, in which then also Android Auto is available.
Would be interesting if someone finds an update for the radio with HW: 036, but think of Desay is not much but wait and see ..
But I take no guarantee - all at your own risk!
On the occasion I would also like to post the list I have corrected a little:
Designation: RCD330 +
Languages: Chinese, English, (Russian)
Part number: 6RD 035 187A
Manufacturer: Desay
OS: Windows CE 6.0
RAM: 256 MB
SW: 0210
HW: 025
supports:
Mirror link
RDS (bugged, station name is small below frequency)
keys:
FM / AM Mute
Media Set up
[Microphone] Phone
Extras:
Play videos
Navigation with GPS module
Manufacturer: No Name (Tianbao)
OS: Linux
RAM: 256 MB
SW: 5215
HW: 526
supports:
Baidu Carlife
Mirror link
keys:
FM / AM Mute
Media Set up
[Microphone] Phone
part Number: 6RD 035 187A (Modded Version)
Manufacturer: No Name (Tianbao, Tempo?)
OS: Linux
RAM: 512 MB
SW: 5215
HW: 526
supports:
carplay
Mirror link
keys:
FM / AM Mute
Media Set up
[Microphone] Phone
Part number: 6RD 035 187B
OS: Linux
RAM: 512 MB
SW: 5314
HW: 534
supports:
carplay
Baidu Carlife
Mirror link
keys:
radio Phone
Media app
[Microphone] Set up
OS: Linux
RAM: 1 GB
SW: 5314
HW: 534
supports:
carplay
Baidu Carlife
Mirror link
keys:
radio Phone
Media app
[Microphone] Set up
Manufacturer: Desay
OS: Linux
RAM: 1 GB
SW: 0317
HW: 036
supports:
carplay
Baidu Carlife
Mirror link
RDS (station name small under the frequency)
keys:
radio Phone
Media app
[Microphone] Set up
Designation: RCD340 +, R340 +
Languages: English, Spanish, Portuguese, Russian
Manufacturer: Visteon
OS: Linux
RAM: 1 GB
SW: 5314
HW: 534
supports:
carplay
Android car
Mirror link
keys:
radio Phone
Media app
[Microphone] Set up
Part Number: 6RF 035 187E (no english)
* there seem to be several versions with different endings (187C etc ..) in different languages
OS: Linux
RAM: 512 MB
SW: 5515
HW: 555
supports:
carplay
Android car
Mirror link
RDS (station name big)
keys:
radio Phone
Media app
[Microphone] Set up
