drooling right now
I posted pics of 235 on 18x8 one page back, perfect fit.I know 235 fits fine, but always thought that was more ideal for 8.5 width.
235 is ideal for an 8" wheel and would fit your setup fine. 225 fits a 7.5 wheel better.
^ 225/40 or any 225 tire is the "recommended" size for an 8" wheel
235 is more ideal for an 8.5" wheel
dont forget that the dealer tends to put tires one to two sizes larger than recommended on their wheels to help with curb protection.
I have a 225 on an 8 and if i lay the wheel down, the rim hits the ground before the tire does. If you look at an OEM wheel with OEM tire it fits square, so i wouldn't say they are putting a size larger. A Detroit (7.5) has a 225, while interlagos (8) come with 235. And for another spin, oem 135i wheels (8.5) come with 245 tires. The rule of thumb is you want a tire thats 1" wider than the wheel width.
8" wheel = 9" tire = 228.6mm
So you can pick. Not to mention the actual tire width will depend on the brand of tire. Here's some more info to help you make up your mind.
http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=198
Hi guys,
finally ready to pull the trigger on some new wheels and summer tires and wanted some advice. Going with 18x8, offset 48mm on DG springs (not looking to go lower), and trying to decide on 225, 40/18 or 235.
Brain is mush trying to find photos of a head on view of 225 on 18x8 to see how they look. basically, is the 225 the perfect/ideal fit for a 18x8 wheel? I know 235 fits fine, but always thought that was more ideal for 8.5 width.
Looks like you have some good answers already. It does depend on the tire you select -- some 225s have wider section/tread widths than others. The 225 Michelin PS AS/3s I have now are noticeably wider on both of those measurements than the OE Pirellis they replaced. They looked a bit bulky on the Detroits; but the Neuspeed RSe12s I was waiting on finally arrived & the As/3s fit much better.
When I was looking at tires, I noticed that the Michelins have similar section/tread widths to many of the popular summer 18" replacements. As you probably know, the Neuspeeds are 18X8, ET 45. I've attached a few crappy pictures that will give you some idea of the fit. The dimensions on the Super Sports you've chosen & the AS/3s are fairly similar.
