I read that wrong. If it was me I would get just the tensioner replaced for now. When the clutch starts slipping, go to a local shop.
So you think the timing chain shouldn't be replaced?
Is there any chance VW will have a recall on these tensioners? I feel like jumping time is a pretty big issue.
Change the chain, the design has proved to be inadequate.
it will eventually stretch. The extension on my tensioner was within spec; however my chain, showed differently.
Original vs New
Original vs New
Those are two completely different types of chains. They might stretch a little but that's what the tensioner is for. Where has it been proven the design is inadequate?
The one the left is the original chain, the one on the right is the new chain. Well, let's ask the question, if the original chain and tensioner are indeed considered adequate, then why the change in design?
The tensioners primary function is not to take up chain stretch but to mitigate expansion and contraction of dissimilar metals (head and block) as well as to absorb reactionary forces from sudden onset of acceleration and deceleration conditions.
Chains do stretch yes, but unfortunately, the original design will succumb to failure, it's design cannot not handle as much tensile force or fatigue as the new one.
For a clearer comparison, I indicated the differences between the two.
The chains pictured are of my old and new timing chain. You can see how much it stretched. This is from my 2009 A3 Quattro. I did not change the chains for the oil pump and balance shaft.I don't necessarily see a design change. One looks to be the upper timing chain, the other looks to be the lower timing chain. Do you have a picture of both the new and old timing chains for both the lower and upper timing chain?
Chains strech, its normal.. even if you replace it the new one will strech eventually. It's a waste of money to replace the chain.
Yes replace the tenisoner but replacing the chain i think is not needed. I haven't seen anyone or read a post where they hand engine failure due to a chain randomly failing.
Wrong dude. A stretched chain can mess up the timing regardless of whether the tensioner is maintaining tension. Replacing the chains is recommended for high mileage vehicles (like every 100k miles or so).Chains strech, its normal.. even if you replace it the new one will strech eventually. It's a waste of money to replace the chain.
I would say it depends. If you do early oil changes and don't overheat the engine, the chains will probably outlast the rest of the car. If you do 10k intervals, I would plan on buying chains.
