timneedscoffee10
So after my F23T install, I have a very small oil drip that's driving me insane.
There's no oil where the return line meets the turbo, so it's not there - and I replaced the gasket, bolts, and retorqued where the return line meets the engine - so I'm confident it's not that.
There's not oil from above - so that leads me to where the oil supply line connects to the engine.
I installed a brand new line when I did my F23T ... the connection on the supply line is a banjo bolt on top of the turbo, and an insert with an O-ring that goes into the block, and is secured with a single M6x1.0x16 XZN8 bolt.
Today I replaced that bolt and added a split-lock washer, and torqued it down as snug as I could - but the leak is still there.
I'm wondering if the line either 1) has a bad o-ring, or 2) needs a gasket that I'm not aware of?
Unless anyone has a better idea - in going to put a bead of Permatex Ultra Synthetic around it...
