So last night i went down to my buddies shop for an inspection for PA, I have a 42DD dp (catless) and i threw lot of codes. So we hooked vagcom up to my car and set readiness codes but we could get the EVAP to work with us causing my car to fail. In PA your aloud to have 1 code on for emission. Does anyone know how to set the EVAP readiness code through VAGCOM? My buddy told me to get a o2 sensor spacer form 42DD and i shouldn't have a CEL anymore and i would be able to pass. Any Input?
You are mixing issues and therefore making it hard for people to help you.
Your downpipe should throw one and only one code if everything is working right and that is the P0420 cat efficiency code. If you have any other codes you have actual problems you need to fix and an 02 spacer can actually exaggerate some of them. Any lean or rich codes or actual codes that say 02 sensor are real problems and have nothing to do with your lack of cat, address them don't throw more crap into the equation.
You say PA allows one code, do you mean one fault code or that you can have one readiness test not pass? Again these are two different things and you kind of didn't give enough information to let anyone know how to help you.
If your evap test is not passing you most likely have an issue with your evap system. Most common is going to be a loose gas cap or a bad seal. After that if you ever had the intake fuel pump worked on and the seal was not properly reinstalled you could throw codes, a leak in the system anywhere else could also be an issue, or a clogged N80 valve.
Is the readiness passing for everything but evap? Yes you can actually get all your readiness tests to pass and have no codes (for a time) even if you have no cat in these cars. They run very efficient and since you can manually run all the tests for readiness with VCDS if you get them to all run and pass then don't drive the car allowing the cat to cool and throw codes you can probably get through as is. This is of course assuming you don't have any other actual issues. I have seen and actually set readiness passed on cars with no cats many times in these applications.
