How's your car running jeez? You're finished with the protune aren't you?
Sent from my SM-N910V using Tapatalk
Dealing with some timing up top. Between my schedule and Alex's it's harder to push out tunes every 2 days like we used to :lol:
PM me if you wish for numbers, it'd be interesting. Are we on similar mods?
Alex, how much psi can you give me if I get a tune with you with the forge WG? I'm peaking 23 and holding 20 to redline now on p&p k04 on stock WG.
Holding 20 to redline, that would be an indicator of a WGA doing its job to be honest. Maybe it's the P&P but 20 PSI at redline is good. Currently with high temps outside mine falls to ~18 at redline WITH the Forge actuator.
Has anyone determined if it's worth putting the forge actuator on a P&P k04 with 91 octane? I have one sitting at my desk with the stock actuator and have been debating for a while if the forge actuator makes sense on 91 pump gas (and would obviously like to do it before it's installed on the car).
There are so many mixed reviews about if it's actually worth it, I can't make up my mind.
Make that 93. More PSI will induce more knock. If you're at the 91 limit now, my understanding is that whatever gains you make by upping the boost you'll have to retract via timing probably to avoid knock.
And, provided you have a leaky WG already, if you're not K04 you won't know lol, so just get it I guess? Via this thread I've learned that apparently WG pressure needs to be 1/2 of the desired boost. So say half of 24 PSI = 12 PSI spring (Forge Yellow). Question is whether the factory one you get meets that requirement.
I've said this before, there's another person with the exact same turbo as me, that's Alex's customer and Alex showed me logs of how his WGA was behaving properly. I presume that person never got a Forge WGA because he/she didn't need it.
Then again, as SC_MK6 said, it's $180. :23:
Damn you're making me wish I would have p&p my k04 before putting it on.
Same
. Not worth to take it out of the car, send it, then back on...at least for me. Do we have an estimate of how much WHP does a P&P job give you over a regular K04?
