What's everyone's lpfp duty cycle looking like? I'm hitting 92% at wot and leaning out to 12's afr.
Checked my second WOT log for this current revision and I'm hitting 80% LPFP Duty Cycle. AFR in the 11s. No meth yet.
My fuel pump will be here friday so hopefully I can get time to throw it on and see if that fixes my issue. Hopefully that's the problem and not the hpfp. I hate throwing unnecessary parts at it but there's not a good way to troubleshoot the fuel system without a pressure gauge tied into the low pressure side.
Sent from my SM-N910V using Tapatalk
Yea oemwhat fuel pump are you putting on ? oem ?
Would there be harm in flashing a CCTA file?
Glad to hear this! I am seeing quite a bit of discrepancy from car to car in terms of fuel delivery. Some vehicles have a good amount of heardroom for fuel while others really struggle with covering even what is needed for a bolted K03.
I've got a brand new filter on mine.Maybe something as simple as fuel filter change interval? Filter restriction = more LPFP duty cycle to overcome restriction.
Oh ok. I was wondering how you determined that it looked like my low pressure side was acting up. I need to look at my logs again to see if I see what you're seeing. Either way, the new pump will be on by Saturday.Tapping for fuel pressure on the low side is not too hard with an amazon kit like this:
https://www.amazon.com/Detool-Injec...=1-1-spons&keywords=fuel+pressure+gauge&psc=1
If you see a drop in HPFP pressure at peak torque this is likely related to the HPFP. If you see a drop in fuel delivery at peak flow (peak hp) this is usually related to either LPFP or injectors.
Try it out for science! Can always go back to the cobb map if it poops itself!
*In scottish accent* YER A SHITEBAG IF YA DINNYYYY!
Yea the accessport wont let you flash a tune if it's sees it's for a different engine code than what it sees when it initially scans your ecu. There must have been some sort of mix up between you and stratified. Just let Alex know and I'm sure he'll have it worked out in no time.Won't even give me access to the tune. They're just grayed out
