Speeddemon691
got shell v power 93 for $2.52 a gallon!
Same
Sent from my Life One X2 using Tapatalk
According to my data log, peak is 22psi (23 on my boost gauge) and taper to 19 at 6900rpms. Im at 100% wgdc at redline so I'm not squeezing anything else out there.
Talk to Alex, get the forge wg, or turbosmart perhaps...you'll peak at least 3-4 psi higher, holding will taper a bit slower.
Where do you have your TurboSmart routed to?
In a few months I will do w/m. Must recharge finances.Are you going to go W/M at all? I think that would be my goal with K04 to get as much out of it as you can within its efficiency range.
Yeah wastegate install requires turbo pull right?Talk to Alex, get the forge wg, or turbosmart perhaps...you'll peak at least 3-4 psi higher, holding will taper a bit slower.
In a few months I will do w/m. Must recharge finances.Yeah wastegate install requires turbo pull right?
Or I remember the axle thing someone mentioned as well.
I would have to talk to my shop to see what they could do.
That's a scary thought of a one way street. Even once I install a new wg, you got to re tune for it right? So I need to do some real savingI was looking art mine last night and I can remove the 2 wg bolts from the top. I'm not sure I could get the new one in, but I can get it out.
Keep me posted if you get it outOoooook, Mark that one a NO on getting it from the top lol, too much shit in the way
I just hit 325/325 today on the dynojet.
I just installed my updated tune with brake boost and launch control. About 5 minutes after the install, I was driving on the highway when my EPC light turned on and the power was cut. So I pull over and turned the car off and on. And the car drove fine after that. So should I go back to my previous tune or was this just a glitch?
