P
plac
Guest
This isn't really any different than Sprint Booster. so get whichever is cheaper. Found on chinese websites:
From the name could you possibly guess what the Wind Booster is claimed to do? If you’re like us and do have some mechanical knowledge you might mistakenly think the Wind Booster improves induction, or the cars breathing, and in turn help to produce more power, but it doesn’t.
The Wind Booster is basically a throttle response control unit that can be quickly fitted to any number or make of cars.
Once fitted (the kit claims it should take no more than 5 minutes) and turned on you will be presented with some flashing red lights! Cool! From there you can choose a ‘Mode’ depending on your driving conditions.
Basic models have 3 modes, Normal (the same as if you hadn’t fitted the unit), Eco (claimed to improve fuel economy) and our favourite SPORT mode which is claimed to improve performance. In actual fact the unit just makes the accelorator more responsive giving the feeling of more power (there is no increase in H.P) This added accelation is said to be noticable, but not enough so to warrant the 1800 RMB price tag. You could probably buy an improved exhaust system and performance air filter for the same price here in the P.R.C!
Installation Instructions:
Find the ECT connector under the steering wheel.
By undoing the safety clip with the screwdriver, unplug the connector and pull it in front of the pedal.
Plug-in the Sprint Booster and the cable back into its initial position.
Connect the ECM cable to the Wind Booster.
Makes sure all connections are firmly in place.
