TSI E85 Tune
WalkerT
The chart on top is a single 3rd gear pull -
e34
95 degress
2000rpm - redline
The chart on the bottom is a 3rd gear to red line in 4th gear.
e34
95 degress
2000rpm -7000rpm shift into fourth to redline
WalkerT
Top is from this morning
e34
82 degress
5th gear pull from 3000-redline
Bottom 2 are from getting on the highway on and off throttle couple of runs
e34
82 degress
several gears
Hoosier Daddy1
Looks promising! I'm going to try this out as well, but since on K04 use varying amounts till I hit the limit. To comment on TSi fueling systems, the injectors are the major bottleneck. Once you go even go a little larger than K04 you need injectors, the system is good for 180 to 190 PSi last I remembered
HYDE161
Fuel pressure looks very close with only minor dips, this shows great results for an E47 Stage 1 or Stage 2 tune on the OEM turbo. Will you go to E40-45 next? 5th gear WOT pull? Hope you're DSG. The best range for clean data is 2,000-7,000 rpm in 4th gear, traction control off, windows up, level surface. The same can be done in 3rd gear but do individual runs, not 3rd then shifting to 4th and taking it to redline in the same exact log. Just do straight 4th gear runs.
Hoosier, the K04 is completely different, the logs I've collected thus far show a definite decrease in fuel rail pressure and an increase in injector duty cycle of almost 10% on E25. When my direct port meth system is turned on, everything levels out again without any issues. It seems that to counter the negative effect of running more ethanol on a K04 tune that we need to offset the fueling systems shortcomings with a water meth system. I will be testing E30 or E35 next for comparison.
WalkerT
All my other runs looked the same.
The EGT average was 820 and never got above 950 and my max MAF was 191.
Fuel pump duty cycle was solid at 75% during all WOT runs
WalkerT
Ryan I am Uni stage 2. I dont run a specific E47 tune. If that is what you mean. Also these were all Windows up flat (texas) surface and yes DSG.
HYDE161
EGT's are calculated through vagcom, do you have an EGT gauge installed?
What block in VagCom shows the fuel pump duty cycle (should be LPFP)?
WalkerT
Exhaust Gas Temperature (EGT): MB 112
-This tells you the temperature at the front o2 sensor as well as projected EGT.
The duty cycle is one of the block available above the rail pressure. I will have to look at lunch to see the block number.
WalkerT
Here is a run with the rail pressure and duty cycle.
WalkerT
Here is the 5 gear run with the duty cycle overlayed
Second chart is my EGT
WalkerT
If you can not log then I would stick to E35 or less. Then see how your car reacts.
Use this to help find out the amount you need to put in the gas tank.
http://www.intercepteft.com/calc.html
Octane result from blending 2 fuels
Calkulin
From my experience of running ethanol blends for almost 2 years now, with the stock turbo, ~E47 is about the limit of where the ECU can adapt(stock tune also), anything much more than that and the car runs lean. I ran E33 for the most part but lately I've started testing E42.5 to see how it does with it and will be dynoing with that blend soon(also will comparing DM Stage 2+ & EuroDyne Stage 2 tunes at the same time)
WalkerT
Fuel pump duty cycle is 106-3
