SFvalleyGTi1
Whats going to cause it to fail overtime? The load we are talking about here is likely to be minute....no real difference to various clips and plugs that holds lots of other lines and cable in place elsewhere...
Heat would probably kill it, based on where its going but you do have a point there. You also have to keep in mind this clip is supposed to keep something down using its own tension. With the metal being heated up and cooled, I would believe the clip would lose its tension or even crack.
When you heat things up and cool it, they usually dont back to its original form 100%.
I wonder why this rattle happens with the K03 and not the K04 and how the actuators are different between the two models.
