Nice chart, for comparison the pre-intercooler temperature on a turbo car is usually around 250 degrees peak, but as you say the same relationships apply.
Science! Good read here complete with formulas:
http://www.gnttype.org/techarea/turbo/intercooler.html
Also, Here's an interesting chart. Even though this example is for a supercharged set-up, IMO the various temperature relationships seem to be pretty close to reality. Sized up IC's on our cars can get closer to Ambient than this though..
And I've posted this before from my old TT with lots of cooling mods Including a huge Forge front-mount:
I think it woukd be very interesting to see....also you don't have to drill or tap into the manifold. That is one thing that always has concerned me about WMI.
I may look into this setup just to try it.
Sent from my DROID RAZR HD
Another thing to keep in mind is volume, while it may be able to drop your IAT to install a HUGE core you have to pressurize the volume of the IC core and this can increase lag.
It lowers the efficiency of the intercooler, rate of heat removal, which can increase the rate of heat soak.
You want the air traveling over the outside of the core to be as cool as possible. Under normal circumstances this would be the ambient temperature. You also want it to be moving as fast as possible. If the air travels over a condenser it will remove some heat, increasing the temp before it gets to the intercooler and the velocity will also slow down.
Heat soak occurs when the rate of energy (heat) being put into the core by the charge air (boost) is higher than the rate of the energy removed by the ambient air. As this happens the temperature of the core material increases which leads to an increase in IATs and lower performance.
When you heat soak what is actually soaking? Is it the actual air? The metal of the cooling fins in the intercooler? Is it like a spongue soaking up to much water and just cant take any more in? Heat being the water and whatever medium being the spunge.
The core material is soaking up heat from the charge air thats getting added faster than its being removed.
For example if you were to do repetitive WOT runs, the core temperature will be, lets say 10 degrees above ambient the 1st time (making up numbers). Heat is added as boost passes through but its not being removed fast enough so when you start the 2nd WOT run the core temp is now 20 degrees above ambient and so on.....
The hotter the core, the lower the rate of heat transfer the higher the IAT.
So it is the cooling element being saturated which leads to the air temps rising which only adds to the saturation and so forth untill no cooling can be acomplished.
You can use a TB Spacer and have no ill effects, it won't toast the throttle body either like if it would if the jet were inserted into the TB Pipe.
I personally think the best route is to do both, TB Pipe + TB Spacer. Offset the nozzles for either chemical cooling or AKI improvement and dial it in from there.
Where would the intercooler nozzle be placed?
Why in the heck didn't VW put the intercooler in the front?
complete heat soak (from what i gather) is when T,enter = T,exit....
Oh the days of wet bulb temperatures, flat plate heat boundary layers, etc. etc.
Hence why IC Water sprayers are pretty effective and even foggers.
Which car company do you work for? I cant remember if I've asked you that question or not. Blue oval I'm assuming? Design or MFG?
