With the C02 setup I was thinking it would be able to operate like a window switch for WOT applications. If you can drop your charge temps below ambient because of the intercooler and the c02 combo, that would allow you to have the computer adjust timing more for a lower temp entering into the manifold.
My thinking at least.
IMO, Better results with W/M in my experience. Cheaper to put a system together, Cheaper to feed (@$4-5/gallon), and equally effective in dropping IAT's to close to ambient...
I've got mine to trigger at 5 psi... and only use 1/2 gallon/ tank of fuel. I can adjust IATs pretty effectively just by triggering the W/M system. I have a turn on light and my boost curve has been adjusted so I can trigger at will by just leaning on the throttle a little. It works well..
Combine W/M with a properly sized IC (I have the GS V1 Twintercooler clone) and it keeps things in a good place for maximizing power day to day even in hot climates like here..
You guys wonder why I haven't gotten a tune....This is one of the reasons.
