U-20ts big turbo build/info thread
U-20T
Hi, figured I would introduce myself and start a thread on my 2011 Autobahn.
My background besides the shop and my VW is in mainly JEEPs. My past build was a very custom regular Cherokee. Then I got my Mk4 and finally the Mk6.
I wanted to big turbo the mk4 very bad but decided to upgrade to an Mk6 since it would be new and fresh. I knew I wanted something different so at 6k on the clock the build began.
Details on the car:
2011 GTI Autobahn CBFA, Candy White.
Mods-
Engine
- Unitronic Big Turbo Software - Stage 3
- Unitronic Low Pressure Fuel Pump (HO Fuel System)
- Unitronic High Flow Fuel Injectors (HO Fuel System)
- Unitronic Cat Back Exhaust
- FFE Racing bottom mount turbo kit
- FFE Racing front mount intercooler w/ Precision 675hp core
- FFE Racing monster intake (post-MAF)
- Precision Turbo SP5858 ceramic ball bearing vbanded
- Tial MVS wastegate
- Synapse diverter valve 1.25"
- Integrated Engineering Rifle drilled rods w/calico coated bearings
- Farrea +1mm intake valves
- Farrea +1mm exhaust valves
- Farrea springs and retainers
- ER Motorsport Intake (pre-MAF)
- ER Motorsport 5" 100cell catted mid pipe
- R8 Coil Packs
- Eurojet Catch Can
- Aquamist HFS-4 Water/Methanol Injection. Direct Port, Pre and Post Intercooler Jets - multi stage controlled
- GReddy B-spec boost control
- BSH pendulum mount
- BSH engine mount
- BSH transmission mount
- Eurocars delrin pendulum bushing
- HPA 90a core interlock puck
- Misc engine heat shielding
DRIVETRAIN
- Clutchmasters FX400 6 puck clutch
- Wavetrac Limited Slip Differential
- USP steel shift forks
- Diesel Geek Six Sigma Short Shift
- Verdict Motorsports shift bracket bushings
- GLI 02Q Transmission
SUSPENSION
- Eibach Street Coilovers
- Eibach 350 lb/in linear rear springs
- TTS strut mounts
- Nuespeed Rear Swaybar
- Powerflex control arm bushings
- Tyrol Dead Set Kit front & rear
WHEELS/TIRES
- Enkei T6S 18x8.5et42
- Bridgestone RE11 255/35r18
INTERIOR/EXTERIOR
- OEM Eurolip
- Shaved front end
- Badgeless grill
- LED Tail Lights
- AEM Wideband AFR gauge
- AEM Fuel Pressure gauge
- Aquamist Flow gauge
- Eurojet Boost gauge
- Greddy B-spec boost control
- Rockford Fosgate PBR300.1 amp
- ER Motorsport underfloor sub box w/ MB Quart 10" subwoofer
- USB dummybutton charger - wire to MDI via K0mpressed
- Moded signals w/ LED
- Full LED interior
- Full LED exterior bulbs
- LED fog lights
- GTI seat inserts
- Rear wiper delete
- Pulled front and rear fenders
BRAKES
- Porsche Cayanne Brembo 17z 330mm fronts - greenstuff pads
- Porsche Cayanne Brembo 330mm rears - greenstuff pads
- Slotted 1 piece rotors
- Dodge Viper/Brembo hand brake
Post 1: Current Setup
Post 2: Previous Setups
Current Setup
To be Patriotic -
More to come :)
U-20T
Helpful info:
Factory Amp Wiring for Sub install
Aquamist HFS-4 Wiring pinouts:
At ECU CBFA MKVI & MKV
Gray main harness:
T90 Connector
- Red Wire (Key Power) pin #3 (red W/ green stripe at ECU)
T60 Connector
- Yellow (FPR) pin #40 (Blue wire at ECU)
- Blue (Map) pin #23 (Green wire at ECU)
- White (Failsafe ECU side) pin #51 (Violet w/white stripe) {possible pin#3 on some models, your #51 or #3 will be empty}
- Brown (Failsafe N75 side) pin #51 (Violet w/white stripe)
Green User Harness (injectors):
T60 Connector
- Red (injector+) Pin #31 (brown w/black stripe)
- Green (injector-) Pin #33 (red w/black stripe)
Board Settings:
CEL - set to DR1
Map - set to 3 bar
Multiplier - set to 2.5x
MKV & MKVI CCTA -
t60
Map sensor is on pin #39 and not #23
WG control is on pin #3 possibly, CBFA wiring diagram showed #3 but it wasn't on an MKVI
zhijjawi10
Very Niiiiice (Borat Voice)
Can't wait to see what happens with this! I run through a shit ton of meth with one nozzle, can't imagine how much you run through. When do all the nozzles spray?
corrado917
Crazy kit,nice i like it.Have you ever dynoed your car?
U-20T
No dyno yet, Have not really had the time.
As for the meth I am going to be running about a 70% mix and 220ml post IC and 150ml into each runner. So alot :)
HFS-4 runs off of IDC so it will take some time to get perfect and I can use MAP to to give it a second stage for boost onset. I will also be wiring in the fail safe so if flow drops it will pull boost.
AXO
JR is a Good Guy. I had an excellent experience purchasing my Eurojet TBE from him.
zhijjawi10
Great. My fail safe setting has me feeling very comfortable. Such a great feature.
U-20T
I agree, your eurodyne controller was my second choice. Decided to go aquamist because of the high volume volume of direct port meth. I do wish it was better integated with controlling boost though.
U-20T
Hey JR why isn't that turbo kit on eurojet's website? Is that a new product?
Its actually an old product called the ej400 and was made for the FSI. I used some of the parts from the kit and some of my own stuff to fit it all together.
A few items can be bought upon special request but its no where near a complete kit.
