Having been on the forum for a while and finally made some decent modifications to my car, I decided to make a build thread to help keep track of everything.
Car is a base model 2013 United Grey MK6 GTI purchased on 6/8/2013 with 418 miles on the clock.
Modifications thus far include:
Engine:
- APR Stage 2 Tune - Installed 4/19/14
- APR Downpipe - Installed 4/19/14
- EuroJet Cat-back Exhaust system
- R8 coil packs w/ plugs - Installed 4/11/14
- Unitronic Cold Air Intake System - Installed 4/19/14
- Diesel Geek Sigma6 Short Shifter - Installed 4/19/14
- Southbend Stage 2 Daily clutch kit - Installed 9/12/14
- Go Fast Bits DV+ - Installed 10/10/14
- Spulen Turbo Outlet Pipe - Installed 10/26/14
- 034 Motorsport Catch Can - installed 12/9/14
Suspension:
- Driver Gear Springs - removed 4/19/14
- ST Coilovers - Installed 4/19/14
- 034 Street Density Strut Mounts - Instaled 4/19/14
- VWR Subframe Mount
- 034 Motorsports 25mm Adjustable Rear Sway Bar - installed 12/12/14
- Tyrolsport Subframe Collars - installed 12/12/14
Exterior:
- 20% Rear/35% Front Window Tint
- P4E Clear Side-markers
- Deautokey HID Fog lights
- .:R LED Tails w/ rear fog
- Klii Motorwerkes Color-matched Rear Emblem Vinyl
- VMR V705 18x8 et45 F / 18x8.5 et 35 R - Installed 6/6/14
- Continental DW 225/40/18 all-around - Installed 6/6/14
- OEM Bi-Xenon headlights - Installed 9/20/14
- R8 oil cap Installed - 9/20/14
- Porsche coolant cap - Installed 9/20/14
- Bold-Sport LED Turn Signal and City Light bulbs - Installed 10/20/14
- Color-matched Side Markers (thanks to John@FTC5) - installed 12/12/14
- Color-matched Rear Hatch Emblem Inlay (thanks to John@FTC5) - installed 12/12/14
- Alzor 620 18 x 8 et45 for winter
Interior:
- P3 Boost Gauge
- Euro-switch with rear fog enabled
- Deautokey Full LED Interior Kit
- Uber-Stealth Subwoofer Setup
- Digital Urban Camo Vinyl Wrapped Trim
- Recaro Sportster CS Front Seats
VAG-COM:
- Comfort Open/Close Windows
- Horn disable on lock
- Gauge Sweep
- DRL Disable through MFI
- Coming Home
- Emergency Brake Light Flash
- Rear Wiper Teardrop
- Seatbelt Chime
- TSC set to 2
- Comfort Turn Signal set to 4
- Driver Seat Heater Memory
- Bi-Xenon coding for retrofit/shutters
- Bulb Saver disable for HID Fog lights
Wish List:
- OEM RNS-510 Retrofit
Engine:
Suspension:
Exterior:
Interior:
- P3 Boost Gauge
VAG-COM:
- Gauge Sweep
- Coming Home
- Seatbelt Chime
- TSC set to 2
Wish List:
