We all have different opinions and choices for the pressure plate and clutch disc combos/separates that we install in our cars. All of the other parts needed for an install, however, are the same for everyone. I have yet to see a comprehensive list of parts, part numbers and torque specs for the parts needed, e.g., bolts, TO bearing, gear oil. Although there are some good DIYs on here and other sites, none of them list all of the parts, part numbers and torque specs. I'd like to create that list here for MKVI GTIs. Post up the parts, part numbers and torque specs that you know and I'll update this first post. Photos would be great too if you have them.
Thanks.
PARTS NEEDED FOR MKVI GTI CLUTCH INSTALL
- Throwout Bearing - 0A5141671F (x1)
- Throwout Bearing Bolts - N90847002 (x3, ?? ft-lbs)
- Pressure Plate Bolts - N90320701 (x6, 14.7 ft-lbs)
- Axle Bolts - WHT005437 (x1 per axle, 148 ft-lbs + 180°, wheel must be off ground when bolt is loosened and tightened)
- LCA/Ball Joint Nuts - N10332002 (x3 per LCA, 40 ft-lbs)
- Pendulum Mount Bolts - N91066101 (x1, 30 ft-lbs + 90°), N91167101 (x1, 30 ft-lbs + 90°), N10558002 (x1, 74 ft-lbs + 90°)
- Transmission Mount-to-Adapter Bolts - N10552402 (x3, 44 ft-lbs + 90°)
- Adapter-to-Transmission Bolts - N10709001 (x2, 44 ft-lbs + 90°), N91133202 (x1, 44 ft-lbs + 90°)
- Flywheel Bolts - N90665001 (x8, ?? ft-lbs + ??°, only needed if replacing the flywheel)
- Manual Transmission Gear Oil (1L) - G052171A2 (x3, only needed if removing axle flanges instead of the subframe)
- Subframe Bolts - ????????? (x?, ?? ft-lbs, only needed if removing the subframe instead of the axle flanges)
Additional Torque Specs
Tools
Thanks.
Tools
