torga
This first comment will be a continuously updated mod list for cataloging purposes.
Drivetrain
Suspension
Exterior/Cosmetic
Interior
Parts Collected for Suspension Upgrade
Recent Photo, as of 1 Nov, 2020.
Engine- TUNE: GIAC Stage 2
- APR cast downpipe
- APR catback exhaust
- ARM Motorsports front mount intercooler
- BFI Stage 1 engine/trans mounts
- BSH TSI 2.0T race intake
- ECS catch can
- Fluidampr crank pulley
- Go Fast Bits DV+
- Graf cast aluminum water pump
- Neuspeed Hi-Flo turbo discharge pipe
- Neuspeed Hi-Flo air charge pipe
- OEM R8 coilpacks (06E905115E)
- Spulen coolant lines (front position)
- Torque Solutions boost tap
- Vibrant O2 spacer, J-style
Drivetrain
- 034Motorsport billet pendulum mount inserts (upper/lower)
- APR Pendulum Mount
- Dieselgeek Sigma 6 short shift kit
- Dieselgeek first gear getter
- Dieselgeek shifter shaft bushings
- iAbed Billet RMS
- Integrated Engineering solid shift bracket bushings
- OEM Aluminum TOB (0A5141671P)
- RSR Clutch Kit
- Spulen Clutch Bleeder Block
- USP Motorsports Stainless Clutch Line
Suspension
- FK Streetline-X coilovers
- H&R 24mm ARB (rear)
- König Ampliform, 18x8.5 - ET43
- Michelin Pilot Sport A/S 4 - 235/40
- OEM Passat aluminum control arms
- OEM TT-RS LCA bracket bushings
- SuperPro adj. endlinks (front/rear)
- SuperPro 70A LCA bushings (front pos.)
- SuperPro roll center adjusting ball joints
- Tyrolsport subframe collar kit
Exterior/Cosmetic
- Helix clear side markers
- Klii Motorwerkes rear badge inlay, color-matched to Deep Black Pearl
- OEM Audi TFSI engine cover
- OEM Black Caps (Oil, Coolant, Washer)
- OEM Euro chin spoiler
- OEM Low-Line upper grille
- OEM R20 LED tail lights
- US Millworks tow hook plate frame
Interior
- Agency Power weighted shift knob (455g)
- Burger Motorsports clutch pedal stop
- eBay GTI seat handle inserts
- NewSouth Redline boost gauge
- OEM Euro switch
- OEM MDI removal & replace with DIN pocket
- OEM RCD330+ head unit
- Polar FIS+ (PF03)
- Rennline phone mount
- 034Motorsport front strut mounts, ECS heavy duty rear shock mounts, KW V3 coilovers
- R32/R front brake calipers, Tyrolsport Caliper Stiffening Kit
- 42 Draft Designs Billet Cable-End Bushings || Beluga Racing Catback Exhaust || BFI GS2 shift knob (215g) || ECS dogbone insert || ECS Short Shift Kit (front-to-back) || GIAC Stage 1+ Tune || NexenN'Fera AU7 tires || Rotiform RSE wheels
