q74
- Car(s)
- R
very curious about the TTS arms on the R. Let us know how it goes!Perfect, thanks for the photos. I guess I was tripping balls haha, I'll just use nuts and bolts then!
and or create a shim to trade static camber for dynamic...
dead center with very small voidsQuick question, do you have any pics of how the rear bushes were oriented in your TTRS arms?
edit: now go to sleep!
it is mounted above the control arm and part #4 is inserted through the ball joint mounting plate from above.Sleep is for the weak. I also noticed you have the BJs mounted beneath the control arm vs above (like it is on the TT), any particular reason?
What are you looking for here as I can shoot you pics of whatever.Quick question, do you have any pics of how the rear bushes were oriented in your TTRS arms?
I'm glad I came across this thread ,but its opened up more questions for which are off topic .
I bought a pair of Hardrace LCA's and they look identical to the original Audi TT 8S arms without any AUDI markings .They have solid rubber bushings .As an options you can get them with Pillow Ball bushings
View attachment 211241 Cheers
Mal
Mine are rubber but fairly stiff. Most people upgrade to the JBX bushings. I am running the JBX rear trailing arm bushings but haven't done the front LCA yet.
https://www.jxbperformance.com/prod...ont-lower-control-arm-bushing-upgrade-a3-golf
Hi bkDid you install that onto a Golf R/GTI?
Hi bk
I'll be installing them on a Golf R . I've sent an email off to Hardrace asking a few tech question's about their LCA's .
The R's fitted with MCA Suspension coilovers ,wheel arches @10+ mm above the tyres and standed wheel & tyre size in Australia on the R ,19x8 with 235/35r19 .
Cheers
Mal
