10" higher on the driver side? Haha this had to be a typo.
I need to roll my fenders. I'm getting some rubbing with my 18x8 et45 wheels.
What size tires are you running? Did you remove the fender screw, pull the plastic clamp out and push the metal up in the fronts?
So...question..I have the performance fronts on my mk6. Bodies are threaded up to make them as short as possible but when I air out passenger side sits at 21 1/4" FTG and the driver is 31 5/8"FTG any way I can get them to even out?
I have:
No sway bar
Notch
Anything else that could be holding up the driver side?
sent from your sister's room using Tapatalk 2
Check a few things:
Make sure tire pressure is even all around.
Check to make sure your fender liners aren't resting in tire. If you have less camber on one side it can push up on fender or liner holding up vehicle.
Check the clamps that hold front strut, are they exactly the same? Being off by 3mm at the strut clamp can articulate and be 6mm at the fender for example.
Also, is your turbo outlet resting on your axle? Mine does and I'd assume this causes the height diff also.
-Dose
