Heartagram131
You know how when you blow up a balloon, you pinch the hole off between breaths? That's what the check valve does. If you don't stop the air from coming out it can't keep air in the tank/balloon...
OK guys so I'm getting a bag set up from bagriders. I am going to get the performance series fronts with bellow bags in the rears and also 2 compressors but which do people on here run and prefer best either the 400CC or the 444cc?
I have dual 400C's with an AccuAir 5 gallon and they fill it pretty quick.
Heads up, make sure to thread those Performance front struts up before installing them. They come preset with about an inch of threads showing and I had to adjust them to 2" of threads to get maximum lift without clunking.
What shocks are you getting? I have 400c x 2 and they are loud AF! You can get black 444 too so if you think that's cool then there is that decision
I adjusted mine to 2.5" and they are great. I don't have any noises and run kind of high but I'm not notched. (24-24.5"/40f-38r) for regular driving but lower when I get the urge.
looking at your build thread you look lower up front. Are you notched?
Did you lose any low adjusting them up that much?
I am notched, and still fully lay out with the fronts set at 2"
I got dual 444c with a 4 gallon seamless and it fills in 40 seconds. Make your you order the Stinger Relay for the compressors. Reason being with the T Taps have a tendency just to burn out, also if one compressor is starting to fail it will draw amps from the good compressor to power them resulting in failure of both. With the Stinger relay you wont have that issue because it keeps them separate.
I am going to purchase the Stinger relay soon its almost bullet proof and a great upgrade for $30
Anyone have the rear slam series shocks? How are they
I bought two water traps and only run one on my car.
