Jekyll991
VW has to use what is easily the worst paint I have ever seen. I've own my car for over 6 months with <6k miles on it. Any forward facing painted surface is ate up with very minute specs that looks someone stood back with a sand blaster from fairly far away and just had it. I also already have several gravel chips ON THE DOOR and even one on the hatch (I only way I can think of that happening is from bouncing off my hitch-mount bike rack last weekend). I do live in an area where you can get ate up with gravels if you follow the coal trucks but I make a point not to follow them.
On top of being easily chipped, everything etches itself into the paint. I already have a few permanent water spots/bug goo spots on the front end thanks to that.
I've worked in my father' body shop for almost 9 years now and I've always thought/said that OEM paint is always more resilient than any paint a body shop is capable of buying, but honestly at this point I believe the paint we use is 10 times better than this garbage. I put 30k miles on my celica which had a full custom paint job the only places in it where from me not sanding an edge well enough or from this one particular even where I was trapped behind some tow truck who was throwing gravels all over the road.
I just hope the paint doesn't fade as badly as some of the beetles we've worked on, I always assumed that the owner never waxed the vehicle but I'm starting to see the true cause.
Is anyone else seeing anything similar? Even if it is common I know it's a waste time to bring it up to a dealer, there's no way I'd let them paint it anyway.
