ChrisAttebery
The last couple times I ran at the track I used 42/35 HOT.
Rs4 have really stiff sidewalls, I love them, on my 3rd set. I usually go about 33 hotWhat tires? How'd that work out for you?
I ran 35/35 hot last time out on 225/45-17 RS4s and there was no sidewall rollover, handling was fine. Next time I think I'm going to try 35/29 and see how that feels.
I follow the wear marks and adjust from thereI spent a good bit of time on Google trying to figure out what was normal to run in these, and it looked to me like anywhere in the 30-35 range was good.
Aw man, I wanted to go but my brake fluid didn't arrive in time. I love the guys at Laps, really a great group. When I first got into tracking they took me under their wing and gave me some excellent instructors. If you get a chance ask to ride in Ken's lotus exige, you'll learn a ton just from going out with himWill be running at Autobahn country club tomorrow - excited to finally get out there. I'll post a quick lap for critique after I'm back!
Haven’t run at a full track yet, but I was experiencing the same feeling. Put slightly better tires on and a huge rear sway bar, helped turn in a lot. That in combination with XDS turned up, makes the car really rotate sometimes. Definitely not for everyone and I’m sure others will have better advice, but I hope it gives you an insight to what some small changes can do!maybe I was expecting too much, but I was really underwhelmed by the car. I had both my Evo and the Golf there, the difference was night and day between the two cars. I was probably trying to corner too fast, but even with trail braking the car did not want to turn in. haven't sorted through the videos yet. I am considering a spring/strut setup to help the car's balance a little more
Have you adjusted your toe as well or no? I’ve heard like 1 degree or two toe out helps a ton as well, but will make it unstable at higher speeds for obvious reasonsCamber plates on this platform are huge, most people see that as a hardcore mod but it's honestly not. You dont need more than -2 degrees in front to significantly improve turn in
