redmist1
Awesome update! I'd like to see the secret test roads! Lime creek? LOL
Dude seriously?!?... Did you forget the first and second rule about Lime creek?
https://www.youtube.com/watch?v=pOa4fvUlhiE
UPDATE: I passed inspection!
Under the professional advisement from Mike at BDTuning, this is what I did:
1) ECU at Stock. (Stage 1 should work too)
2) Installed this http://amzn.com/B00AQ7972O
3) All systems READY and no Check Engine Light. Done!
Just got my results back and they say that two monitors are Not Ready, one of which is the O2 sensor and other is A/C?? They seem to think just driving it will make them fine but I’m pretty sure it’s the tune messing with them. How do I fix it so those are Ready and I pass???
Short answer is you can't without flashing back to stock mode. The readiness monitors are disabled on the stage 2 chipped tunes. If you have the EMCS map switching, you can just use the cruise control stalk to switch back to the stock map.
See similar thread from a couple weeks ago:
https://www.golfmk6.com/forums/showthread.php?t=119774
New tune is applied and I’ve driven in stock mode long enough for the check engine light to come on. I’d assume that means the tune isn’t blocking the readiness monitors now. How do I go about getting the light to go off and all the monitors showing ready like needed? The tuner said he could do it by flashing to true stock and getting them to pass and then get tested but it sounded like a huge hassle and I’d prefer to not have to pay for another emission test at a different place.
