This is what I'm talking about on the front... I can post the code if you need it...
http://www.youtube.com/watch?v=RXijdiQ1XLY
The rear tails I installed LED blinker bulbs (required bulb modification) and they throw NO ERROR CODES! :thumbsup:
I'll just post it anyway... the trick is telling the car you are in a different country other than the US.
First you need to go into 17- Instruments then long coding helper and change you country to anything other than USA. I set mine to RoW.
Once coding is accepted, you need to go to 09-Cent. Elect. long coding and find the check box (forgot the byte) that says disable "DRL when turn signal active." or something along those lines... Once that is done, your LED's should behave like ones in the video posted in this thread.
