got me a check engine light!
1 Fault Found:
000665 - Boost Pressure Regulation
P0299 - 000 - Control Range Not Reached - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 0
Fault Frequency: 1
Mileage: 35675 km
Time Indication: 0
Date: 2026.14.17
Time: 15:45:03
Freeze Frame:
RPM: 3520 /min
Load: 89.0 %
Speed: 94.0 km/h
Temperature: 97.0°C
Temperature: 41.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 13.716 V
ive looked it up and all signs point to the diverter valve. should i even bother going to my dealership (which i dont have the nicest relationship with since stage 1) or should i just change the diverter valve myself?
I've also have this random code i can't figure out if anyone wants to take a crack. searching showed no real answer.
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 5K6 920 970 H HW: 5K6 920 970 H
Component: KOMBI H03 0305
Serial number: 00000000000000
Coding: 270F00
Shop #: WSC 01357 011 00200
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
VCID: 3957F098B842B31
1 Fault Found:
12658432 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 254
Mileage: 34618 km
Date: 2025.14.26
Time: 17:18:33
Thanks!
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 35675 km
Time Indication: 0
Date: 2026.14.17
Time: 15:45:03
Freeze Frame:
RPM: 3520 /min
Load: 89.0 %
Speed: 94.0 km/h
Temperature: 97.0°C
Temperature: 41.0°C
Voltage: 13.716 V
Coding: 270F00
1 Fault Found:
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 254
Mileage: 34618 km
Date: 2025.14.26
Time: 17:18:33
Thanks!
