So when installing front shocks I normally use the elliptical spreader socket and almost always it works fine and with some pressure from jack it falls into place. This weekend I was installing new struts and the elliptical worked fine on first one, then on second shock it did not spread enough for me to get the shock fully seated. Come to the rescue an alternative spread tool that I highly recommend. Purchased off Amazon for 34 bux. It has the ability to spread further than the elliptical and with this tool the second shock dropped right in. From time to time I see posts about folks having to sand paint off etc to get the shock to drop in. This tool takes care of the issue.
You hold the body of the tool with a 17mm open end wrench and turn the black threaded top with a 17mm socket. Works great!!
