HSTuning
HS Tuning is proud to announce that we are the USA distributor for Bilt Hamber detailing products!
Bilt Hamber Laboratories are formulators and manufacturers of multiple award-winning surface-care
and protection products including; corrosion preventatives and removers, lubricants, polishes, sealers
and metalworking compounds for automotive, aeronautical, marine and industrial applications
Some of what Bilt Hamber has to offer:
finis-wax's high grade T1 carnauba wax is used as the backbone to provide a deep rich gloss, while unlike other
automotive waxes excellent gloss, ease of application and buffabilty are provided by other gloss enhancing
molecules.
auto-QD is a unique concentrated quick detailer spray , particularly suited to use over auto-balm, but also with a
wide range of other uses like freshening up a recent detail or wax application and maximize your shine.
auto-wheel’s pH neutral formulations reacts with the oxidising surface of the metallic particle rendering it
water soluble, the rapid removal of this microscopically rusted surface reduces the embedded particle size
and releases it from the surface, unlike acids this method is harmless to the wheel’s finish
surfex HD attacks all oil and grease based soiling, but unlike traditional cleaners will effortlessly
clean organic or water deposited grime. surfex HD can be adjusted in strength to suit the level of
soil, remaining active at levels of just 1:200 in water for light work, or used full strength for extreme duty.
deox-gel is a viscous, highly thixotropic, rust remover, designed for corrosion removal on surfaces or
objects too large to submerge in a bath of deox-C. Along with the viscosity builders and preservatives,
the active agents in deox-gel are harmless, non-toxic and biodegradable
There are a lot of other products as well that we have added and will be adding even more in the nest little bit.
We have loved the results we have seen so far from testing their products in our shop over the last six months,
and are glad to be able to offer them to customers on this side of "the pond"
