iiCaptain
I swapped tunes on my accessport to a 93 octane stage 2 tune I had used before, and afterwards noticed an issue with acceleration. Anytime I step on the throttle, it builds a little boost, hesitates, and then builds the rest. It doesn't affect normal driveability, just any time I get on it. It's most annoying on shifts, as after I let out the clutch and get on the gas it hesitates and then the torque "punches" I guess is a good way to put it. I took a datalog to make sure I wasn't imagining things, and I found a ~400 ms pause as the boost builds. From no throttle to full throttle the boost pauses halfway at 6-8 psi for about 400ms before it continues and builds full boost at a normal rate. I've swapped tunes and the issue still follows, and I've stayed on the same tune now for a full tank of gas to try and let the tune adapt to see if it was that, didn't fix it. Out of curiosity I tried NLS (I normally don't use it) and it's still there.
Now I'm 99% sure this popped up when I switched tunes, but I'm not sure. I don't normally row gears and usually roll into the throttle which makes it a lot less noticeable. Still there, but harder to notice.
There's no codes or faults or anything, so I'm not sure where to start.
Here's some info on the car and thing's that might've changed.
-Attached O2 spacer to middle O2 sensor (cbfa). Don't think it is this due to me driving for about a week on this before this issue popped up. The reason I swapped tunes was to test the spacers.
-Haven't tackled carbon buildup yet (74k miles). No other symptoms of carbon buildup yet.
-Have CAI, any chance the filter didn't do enough filtering and messed up the MAF?
-When I searched this I just saw a bunch about the throttle adaption. Tried it and it did nothing to fix this issue.
That's all I got, appreciate any help. I searched for a while and didn't find much of anything online so not sure what to do.
