MrFancypants
When I dropped my car off to get a new intake manifold installed the service adviser said they found a few oil leaks. The upper timing cover which is obvious, a camshaft carrier, and the air pump.
I've been searching and I can't figure out exactly what part they were referring to. At first I thought he was talking about the valve cover, but that doesn't seem to be true.
The only thing I can come up with is maybe #15 on this diagram?
...which would make sense because there is a bit of grime in that particular spot that would lead me to believe that a bit of oil is seeping from there.
The dealership wanted $1400 to replace all these gaskets, which seems excessive because two of them are right on top of the engine.
For the life of me I can't figure out what the "air pump" is that they're referring to either.
My car loses about a quart of oil every 10,000 miles, so I chose to put off the repair. Unless "thrust piece 3334" is super expensive or difficult to buy two of these should be pretty easy to do in the garage.
Page I got the diagram from...
http://workshop-manuals.com/volkswa...gear/valve_gear/assembly_overview_valve_gear/
